HandLogger
With the help of a fellow HEF member, I received a CAT PDF file called "Diagnostic Codes." The written procedure in this PDF calls for two items: a Diagnostic Indicator and an "ET."
Pulling diagnostic codes from a piece of heavy equipment is a new thing for me, so I'd like to ask the 420D folks if they have any experience in this regard? Can the codes be pulled with only the Diagnostic Indicator or is a CAT ET actually required?
DISCLOSURE: Quite honestly, I had to look up what a CAT "ET" is, and my findings are that it's an adapter that allows one to interface a PC laptop with the ECM on a CAT machine. Anyway, I'd appreciate any thoughts on this matter.
Thank you for your time ~ HL
