CAT 420D Not Shutting Off
CATinLiberia
Liberia, West Africa
Missionary and Community Development
I have two CAT 420D machines exhibiting the same issue: When I turn the key switch off, both continue to run-on at a slow RPM. To kill the engine, I either have to actuate a hydraulic valve or turn the key back on.
A local electrician told me it is either a dirty/defective solenoid that kills the engine or a defective key switch. As a rule, I will trust Satan before I trust electricians in this country. Because I have to ship all parts to Liberia from the U.S., I want to be certain the cause before shipping replacement parts. Even better, it would be great if I can fix it myself on this side of the pond!
Any thought?
Eric
CATinLiberia
BTW, if it helps, here are the PIN #'s for my backhoes:
CAT 416D – PIN # CAT0416DABFP14642
CAT 420D – PIN # CAT0420DAFDP26886
CAT 420D – PIN # CAT0420DCFDP23847
Thanks!
kbeen
oklahoma
Can you try un-hooking the wire that goes to the shutoff solenoid and see if it dies then, if it does then take a voltage meter if you have one and see if you still have power on the wire that goes to the shutoff solenoid when the key is off.
CATinLiberia
kbeen- Thanks for the advice. I will check that out and get back with you.
BTW, where are you at in OK? My backhoes shipped from Fairview.
