CAT 420D IT
BigBoyToys
Michigan
I just purchased a 2004 cat 420D it backhoe. I just installed the multipurpose bucket and can’t figure out how to make the clam shell open and close. I have the yellow buttons on The loader controller. When I push them nothing happens. I switched the valve in the front loader, the lever that is for the locking pins, and still no function.
Is the attachment what you are trying to do..?
If the locking pins won't move when the switch is moved then possibly you have an electrical fault.
If you don't have an Operation & Maintenance Manual yet it's probably the best $46 you'll ever spend. Go to: -
https://catpublications.com/
When the popup appears click on "Continue as Guest"
Type SEBU7399 in the box and click Search. The illustration below should appear. Download paid for with a CC is available immediately.
  • Bucket R&I.pdf
PDG X
Florida
Owner Operator
With the valve on the loader in the vertical position, depending on which loader controller you have, either slide the thumb switch left and right, or use the roller. The yellow buttons are for electrical functions, not hydraulic functions like the MP bucket..
