I am not new to backhoes. I ran a Case 580K for a number of years.
That was easy with it being new and everything being marked...
Just picked up a used Cat 416C today. ~4000 hours on the clock. I was told it was used by a utility installer company.
Serial Number *5YN05###*, Arrangement 1431736. Is there a rhyme or reason to the serial numbers to tell what options were factory installed?
Doesn't seem to be worn too bad. Not worn OUT like the other backhoes I have been presented with. Came with a 12" wide bucket.
It has hydraulic hoses Tee'ed off of the extenda-hoe hoses with some quick connectors down by the bucket. (Pin the extenda-hoe solid and use the hydraulic for something else...) I'm thinking maybe they had it available to use a plate compactor. I can't really tell if they DID use the extra hoses. Any other guesses why the extra hoses?
I am sure I would like a thumb. I don't know if it is ever going to happen. Is that going to be a WELD-on option? or do they bolt on somewhere?
Looks like it never HAD windows or doors. Just the two lower glass pieces in the front of the cab. No hinges on the door posts.
I'm trying to figure out what the switches on the dashboard do. I don't know if I am not seeing something that a switch is supposed to do or if something doesn't WORK. :beatsme Is there any place that I can get a picture or quick show without buying a manual?
I expect with there being no windows, there will be a blank space somewhere that a switch for windshield wiper would be. Would the switch be UP on/by the wiper motor or DOWN on the dashboard?
No heater or A/C. I don't know if they were an option or not. There could be a blank space somewhere that no switch is since it isn't installed?
I am trying to remember what all switches there are and what they do...
I do remember seeing some BLANK spaces where switches COULD be.
One switch on top left dash that goes left and right: That controls turn signals.
One switch on the left dash, next row: Seems like I figured out what it does, but I can't remember right now.
Second switch turns on 4x4? I think I got that figured out.
Third switch: Didn't find anything immediately obvious that it does. ??
Seems like there were some switches on the dash to the right of the steering column. ??
There are ~4? switches UP to the right side roof of the cab that turn on lights. I didn't check them to see what they all do (or not).
I don't remember seeing switches when turned around to run the back hoe.
I don't even remember if there are REAR lights. :beatsme Should there be other switches somewhere in the back of the cab for back lights? or are the ?lights controlled with the ~4 switches UP to the right in the front of the cab?
The lever on the right side (when swiveled around backwards) that lets the hoe latch loose seems to have the cable thingy too tight. The hoe latch just barely grabs on the pins. I have been used to the Case method of having to over-center the hoe and reverse the lever at the proper moment to get it to latch up. This CAT seems like it just gets the hoe up close and slows down and comes on up.
Parking brake? I think that is what this thingy on the floor is supposed to be. The lever was pulled up when the tractor was brought to me. It doesn't seem to do anything. The regular brakes seem to work; I didn't really TRY the brakes. Is there a parking brake that is SEPARATE from the foot brake?
What is the extra set of pin holes in the bucket for? Is it supposed to be used in the top set of holes or the bottom set of holes?
