james van dyk
Have a 416C cat that i wish to put a block heater in. i have seen threads for replacing a 416B block heater, which is on the left hand side of the engine behind injector pump with screw in port. 416C calls for placing it in freeze plug on right side of engine. the recommended position is upper center freeze plug, which is behind intake manifold. placement would necessitate removal of intake and likely exhaust manifold and all connections. i see 5 other freeze plugs on the right side that are lower, does anyone know if any of them, specifically which one, go into the water jacket and whether i can use one of them? i really don't wish to knock them all out to find none of them are in the water jacket. thanks for any help.
