Cat 416b front pump coupler replacement
ckesse1
pennsylvania
My pump coupler needs replaced. Is there a way to replace it without removal of counterweight? Any help appreciated
edgephoto
Stafford, CT
Post your serial number so I can check the repair info.
I have a 426 and I replaced the rubber coupler when I changed the belt. It was not hard. I want to see if it is the same design.
AzIron
Az
If memory serves you can replace the rubber coupler pretty easy without removal of anything but the belts to pull the pump requires removal of counter weight
