I have a cat 416B backhoe that the engine died on while roading to a new job site tonight. All fuel filters were Changed very recently and it ran fine until tonight. Of course when needed for an emergency water line repair it won't run. It will run with wd40 but sputters and dies quickly afterwards.
...... While priming the little hand pump on the side of the engine I noticed bubbles in the glass bowl consistent with each stroke of the little pump.
The glass bowl is full of fuel. I'm going to try and work on it in the morning just trying to get any suggestions or help I could get before I set out. The fuel priming pump looked wet with fuel like it was seeping after I pumped it about a thousand times trying to get it to start/ primed up. I didn't have time to break the bleeder at the top of the glass bowl to verify I was getting fuel. I ordered a new priming pump and it will be in in the morning.
The Air bubbles make me think I'm sucking air somewhere from the priming pump or somewhere before it back to the tank. I read that this pump has a small filter in it and if it does it's got 3000hrs on it .
Any suggestions would help me expedite this repair on the very busy road it's stranded off to the side on. I've been addicted to this site and have followed it daily for years but never posted very much on. The amount of knowledge, friendliness, and compassion to help others cannot be seen on any other site I've come across. Thank you for any advice in advance..
