pumkinhead
have a cat 349 (hpd prefix) that throws a e1052-2 Low Aftertreatment #1 Fuel Pressure #1 every 20-80 hours (machine will not regen with this event logged). I have not been at the machine when the code is active and have not been able to recreate the code while im on the machine. fuel pressure at the priming pump has always been at the high side of spec while im on the machine and has always sucessfuly completed ARD ignition tests and will active regen once the code is cleared and will not log the code again for a week or two. I replaced the ARD fuel solenoid (updated solenoid) and both pilot and main soleniods on the ARD fuel manifold along with both pressure sensors. any sugegestions would be apreciated
