My 2000 3406E rated at 550 hp was turned up to superman strong when we got the truck. I don't know what it was set up to, as we never dynoed it, but it could haul a D-8R, at 126,000 lb gross, up a 6% grade at 55+. After running it a few years like that with hired drivers, we had to have the top end worked on, and made the mistake of taking it to the Cat dealer. When we got it back, the driver complained, so I took it for a load, and called Cat to find out why it would barely run. Found out they flashed it back to stock. :-( Now the same pull with a D-8R is done at 35, instead of 55+, and the worst bit is that it dropped from 6+ MPG to 5- MPG :-( :-( And they refused to put it back. Seems CARB won't let them.
I suppose it will last longer now, and it is still strong, but it is nothing like before.
