I will try to keep this short and sweet. I have a fairly new to me cat D6H that has had a 3306 PC engine put in it at some point in time. It has about 50 hrs on an in frame and rebuilt head. I finished a job with it about a month ago and it seemed to be running fine. This morning I went to move it to another job. I evidently had not turned off the master switch and the 2 month old batteries were completely dead. Jacked around with jumper cables for a little while... weren't gaining much. So took the batteries out and brought them home and put them on chargers for a few hours. Also noticed an end on the negative cable going to the master switch was a little loose. Put a new end on the cable and put the batteries back in the machine. When I would turn the key to start it would make about 1 slow revolution. Only tried it twice. The guy helping me noticed when I let off the key the engine would kick back a little. We are thinking it is acting like it's hydro locked. My next move was to pull the glow plugs and turn it over by hand and see if anything comes out of the glow plug holes. My question is... Am I on the right track or is there something else I should try first? TIA
