tctractors
Bryant, it is possible to spill time this engine with the fuel pump that you have fitted, I have done this task a few times when I have not had my lock plate, this is via a timing disc (bit of plastic) that is of no weight that I always keep in my chariot, I know its not an issue now that you have the correct tooling but it not a hard task to cope with if you have a bit of plastic, anyhow the learning curve is on full flow for you, so please dont be slow to ask about anything that you are not sure about in future before you pull things to bits, as 2 grind marks on the drive gears would possibly have saved you a few coins, oh and on the spill time thing the 3304/6 does have the TDC pin point, so with that set and the disc poked on the front of the crank and fuel in the tank its not hard as even a dummy like myself can cope, it helps to have the throttle control off the stop position though!!!
very pleased that things worked out well tctractors
p.s. my lock plate also fits the D8H/K compact pumps as I drilled it to fit and sold my D8 lock plate, so 1 tool fits all (sort-of)
