CAT 329 Track Function
Discussion in 'Excavators' started by ms0115, Jan 7, 2020.
  1. ms0115
    ms0115 Well-Known Member
    Mar 3, 2014
    210
    Ethridge, TN
    Serial #CAT0329ETPLW00668 Problem- periodic loss of one track function. Shows a data link code as well as the 3 others in the picture. I had CAT come out in November and they did an update on data link per service bulletin. This did not help the problem. Replaced the swing priority solenoid and the stick cylinder extend pilot pressure sensor. The codes cleared except for the data link. The machine operated fine for 3 weeks with no issues. Now the track started to loose function again and the codes came back. Any advice or direction on how to proceed would be appreciated.
  2. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    924
    heavy equipment technician
    victoria,Australia
    hi,I am assuming cat re-flashed the monitor software for your communication errors,but I don't see that as the source of your problem for loss of track function.
    The track system still uses a pilot oil system that controls the main control spools for travel
    There is a bulletin out for the travel check valve in the main control valve .Has that been checked and or replaced?
    Has any recent work been done that could be related?
    Is only one track affected? If so which one?
    If only one track is affected try swapping the travel pressure switch's, under the floor on the travel pilot control valve to see if the problem moves
    Does the track stop or slow down?
    is the machine fitted with the straight travel pedal?
    Are any other functions affected?
    Have you checked for debris in the filters?
    Does the problem appear to be temp related ?
    Can you recreate the fault yourself?
    Sorry for all the questions just trying to get a feel for your problem
    Mark
  3. Mark250
    Aug 30, 2015
    924
    victoria,Australia
    travel pressure switch's #2 and #8
  4. ms0115
    Mar 3, 2014
    210
    Ethridge, TN
    The problem has been intermittent. The reflash was dealer suggested. No the travel check valve has not been checked. Could you give me any more info on the check valve. Location
  5. ms0115
    Mar 3, 2014
    210
    Ethridge, TN
    Is there any way to get parts numbers? Thanks for the help
  6. ms0115
    Mar 3, 2014
    210
    Ethridge, TN
    At the cat dealer and they are having trouble finding the parts. 3 hour ride to the job just taking parts to be safe
  7. ms0115
    Mar 3, 2014
    210
    Ethridge, TN
    They got it figured out on parts. Will up date tomorrow.
