bsamot69
Our CAT 320D excavator, serial# PHX01833, does not start. It displays a low oil warning. The oil level is correct. In the recent past, the machine was temperamental when starting. It had to be on level ground or no go. When shutting down, better make it level or the next time you use the machine, starting would be difficult. Now, it thinks it is out of oil?
Is the oil level sensor accessible? Am I on the right track assuming the sensor has failed or wiring defect? Are there wiring diagrams available? Thank you in advance for any advice.
