Bosvark Kzn
My CAT 320c (CAT0320CJANB03733) stalls the engine when curling the bucket in and out, also on boom up it stalls when the boom reach full up position and I don't let go of the joystick immediately (even on full throttle). It travels perfectly, no problems.
I have replaced all fuel lines, removed and cleaned the fuel tank, new fuel filters and checked the small screen in the banjo. Fuses all good, wiring on the PRV solenoid looks good, the engine speed sensor is clean. Disconnecting the PRV solenoid makes no difference. The toggle switch under the rhs armrest is in the AUTO position, but makes no difference if in the MANUAL position.
I haven't checked any oil pressures as I don't have the correct gauges and I haven't checked/tested anything electrical with a ohm/volt meter. The original throttle control has been removed and a manual hand throttle installed. Could this possibly affect the PRV operation?
I found the following fault codes today, but don't know what it means.
Active:
69: 587-03
Logged:
69: 600-04
69: 96-03
69: 587-03
69: 587-04
69: 587-08
69: 374-05
69: 376-05
69: 581-05
69: 600-10
69: 110-10
69: 190-10
69: 167-08
69: 190-08
69: 168-05
69: 588-12
69: 254-12
I'm not sure what to check/test and will appreciate advise on how to rectify the problem.
Active:
69: 587-03
Logged:
69: 600-04
69: 96-03
69: 587-03
69: 587-04
69: 587-08
69: 374-05
69: 376-05
69: 581-05
69: 600-10
69: 110-10
69: 190-10
69: 167-08
69: 190-08
69: 168-05
69: 588-12
69: 254-12
