Gary Layton
These are the specs for my machine:
sn PAB06638
Engine SN MAE05872
AR No. (arrangement) 2870092
My CAT 320CL shows an "E" when you run the A/C or even just the fan.
When I accessed the error codes at startup (hold temp up and down at same time) I got a flashing Error 43 on the HVAC screen. From another thread I found this:
"43 is for incorrect movement of the discharge air damper. "
I have looked thru the SIS that I can access and do not find a "discharge air damper." Is it called something else by CAT?
Is it behind the seat? What makes for "incorrect movement"? Any tips appreciated.
sn PAB06638
Engine SN MAE05872
