Pepe
I posted under General but forgot about this one 7 not sure how to delete under general?
Had older CATs but first time with a Monitor? CAT 312 BL Serial 8JR..... 3064T motor --- Oil & Filter changed--level cold fine. Ordered Op & Maintenance manual awaiting Oil pressure guage to test the sensor but have a Cat 320 Op/Main & no help. Noone here has a Workshop Manual I know of. Starts OK --runs fine no knocks or problems for about an hour working then the buzzer sounds; oil pressure red box comes on. I was told sensors can go so once I do a test then will replace but wonder why so long running. Only run on 3-4 clicks farm work. Water temp/hydraulics fine. I know nothing about the monitor or how they read--help needed if anyone can assist esp on the right buttons -- but happy to learn as can't find any info? [Pic shows monitor when buzzer went off]. Could the problem be the sump engine level sensor also triggering the buzzer? Can't see any oil cooler on this model? but appreciate any comments. Also can low oil levels eg. oil level switch on sump trigger the buzzer? I will check further if not the problem? Thank you.
