A purchased 312B -
When cool/cold hydraulics are strong. After working and heating up the hydraulics get weaker. Travel is slower and will not pull out of a steep area. Swivel is slower, hydraulic pump 'noise' sounds 'noisier'. Digging is less 'strong'.
As a -purchased- Cat I was wondering if 'old' hydraulic OIL might be the cause. Lower VISCOSITY under heat ?
Or . . . is the PUMP not putting out the VOLUME at higher temperatures.
45 gallons of hydraulic oil is -expensive-. . . . . as is a pump.
