Hello all!
Sorry for hijacking the thread, but since im a new member i cant do new posts
Got a problem with a Cat 312C, one day it just started to stall when turning the rpm knob down to step 1, and lacks alot of power when using the hydraulics, but idles fine and runs well on all steps (1-10) when you dont operate any hydraulics , but specially noticeable is when lifting the main boom or lowering, and seems to be weaker when tracking bakward than when you tracking forward. Also response slow when moving the joysticks, takes a while before the throttle response, (have not been like this before)
The fuel filters are replaced with orginal cat ones, the aircleaner is cleaned . But still same problem.
My first tought was the fuel filters but that didn`t sort my problem out
Second was if there was any problems with the throttle cables adjustments, but it do get a little better or worse when adjusting them, but i have no right calibration on it at this moment.
Any one have an answer on this symptoms? Or any thing to try to sort out where the problem is?
Regards,
Christoffer
