CAT 3114T Engine 80 HP year 1989 wants to stall after engine starts
The screen #25 is washable. Unless it is damaged it should not require replacement. However if you are using the machine very little (and by the accumulated hours since new it sounds like it) you should really be removing that water separator every 3 months, 6 at the outside, to check for the presence of water. Machines that don't get used very often wll accumulate water through condensation in the tank. One way to reduce the chance is to always keep the tank full of fuel.
bam1968
IA
Excavating Contractor
I have a 920 that had similar symptoms about a year ago. It has a newer style fuel cap on it and the vent on the cap was almost completely plugged off. It would start and idle just fine but would bog down after a minute or two of actually using the loader. Just my $.02
lake side bob
minnesota
owner operator
I have checked this part numbered 25. I have changed it in the near past. It was clean LIKE NEW,there was no water so this can not be the problem.
Do you have any suggestions?
lake side bob
minnesota
owner operator
I also opened the fuel tank drain valve and drained out some fuel did not notice any water.
Follow the advice given. What's the history of the machine? how long owned? how long the problem's existed?
Bluox
WA state
Check your fuel pressure at the port on the final fuel filter, at high idle should be 29 to 58 psi. If it isn't check the check valve in the fuel return line. Also there is a internal screen at the inlet on the fuel transfer pump. If all else fails go to your Cat dealer and ask them to print out the pages from systems operation testing and adjusting, they have actually seen one of these engines!
Bob
Zimbo
Western Australia
3114.... sleeves in head allowing combustion into fuel. Ensure the water pump belt is tight as
Usually it slacks off allowing engine temp to raise and affect sleeves. Clear tube on return line out
Of head will be the go.
