Hello…I was wondering if anyone could share a schematic for the relief valves on a 2014 cat 308e2 cr…fjx00370…just purchased and blade does not have enough blade pressure to lift the machine…will stop once it hits ground resistance…not making any noise and no visible leaks..used the bucket to lift the machine up and bottomed out the blade…when I lowered the machine down it immediately raised the blade to ground height…no noises and no visible leaks..thinking air bound or bad blade relief valve…could there be any other areas to check? Thanks for any help. Todd
