Cat 305c cr throttle issue
Nicholas1834
Milford pa
I had an issue where the throttle was stuck wide open turned out to be a pin on the connector was faulty. Fixed the pin and now the throttle only moves 25% roughly and doesn’t do the full range of throttle. Electronic dial throttle, that has no issues. Is there a way to calibrate the throttle to get the full range of motion out of the actuator?
