cat 3024 ct question about piston oil cooling jets
OzDozer
Perth, Western Australia.
Semi-Retired ..
The Cat 3204C-T is a nearly identical engine to the Perkins 404C-22T. They are both built in the Caterpillar/Shibaura engine factory.
I see no reference to any piston cooling jets in the Perkins 400 series manual, for either naturally-aspirated engines or turbocharged engines, so I cannot see where Cat engines would have them.
There are minor differences between the engines according to application requirements, but the basic engine structures are the same.
patreeot355
akron, ohio
i so appreciate that info!! have a turbo engine i boaght remanned and it always ran hot in my stump grinder, and the block cracked in the front between the cam and freeze plug. the engine ran great,when removed. i found a non turbo engine that supposedly had low compression. hoping to make one from two
