GroundWorks
I have a 2004, Cat 301.8 with 1700 hrs on it. When I select "fast" travel speed it'll blow a fuse. Would anyone know if this is a common issue? I haven't taken the switch out yet to check for a live (power) wire living too close to a ground source. Normal crawl speed, no issues, but as soon as the travel switch is engaged for fast travel it blows a fuse almost right away. Not sure what exactly this fuse is for, but once it blows I lose all hydraulic power (everywhere) yet the engine will continue to run. Once the engine is shut off it will not restart, even though there is power to lights, horn, etc. Change the fuse and she'll fire up and operate as per normal. Anyone know if there were any "fast travel" speed issues with the 301.8 that would blow a fuse?
Thanks,
Gary
Thanks,
Gary
