Pvequipmentrepair
I am having the same issue. I have only 5v on the right side to sensor. 8v on the left. I guess I need to track back and see where I’m losing 3v at for the right side. I know it starts at the ecm.
If you have 8v on at least one side then that eliminates the ECM as a possibility. Do you have an electrical schematic.? If not then a machine Serial Number gets you one.I am having the same issue. I have only 5v on the right side to sensor. 8v on the left. I guess I need to track back and see where I’m losing 3v at for the right side. I know it starts at the ecm.
What Code exactly are you getting.? Also the machine Serial Number please.I am running into this issue with a 239d3 wheeled skid loader. Swapped sensors and problem did not switch sides code wise. Checked voltage between the 8v supply and return and I’m getting 8 volts the sensor side of the plugs I’m getting 5 volts. I’m at a loss here. It isn’t affecting the machine’s operation it’s just annoying because it beeps incessantly
