Rod end of the cylinder on my 299C is oblonged a bit where the pin goes through, and I was curious if there is a bushing in there? I've degreased and wire brushed it but can't see a seam or such. Found Cat part number 3K-2151 which appears to have the right ID and it's description references the schematic for the tilt cylinder, but I'm not seeing it in the parts breakdown.
Does anyone know if this is a pressed in bushing from the factory, or an option to have your rod bored out and repaired later as it wears?
Thank You.
Thank You.
