Acoals
Cat 289D, Serial TAW01488
I was running the machine this afternoon and the advanced display started beeping and displaying a red warning with code E-695-3, I couldn't get a picture of the warning, but something about unexpected speed and high speed would be limited. The red warning would intermittently come on, beeping, and then go out. There were no symptoms with machine performance, high speed worked as usual.
Shortly after the E695 code a yellow warning came up with code 41-4, 8 volt supply below normal. This code warning could be cleared off the screen, but would pop back up periodically and have to get cleared again.
The triangle with the exclamation point lit and stayed that way.
There are a number of codes in the history folders, but there are several folders in the Advanced Display and I am not real familiar with what means what. At least some of the history codes I am pretty sure are old from issues a couple years ago.
I do not have access to ET at this time, wondering if anybody has any suggestions which direction to start?
