Cat 289C hydraulics locking out but no code.
Casper16
help anyone. My skid steer cat 289c I hop in start it I can lift arms up but as soon as I come down on the arms it will come down a fraction then locks out the hydraulics but the lockout light doesn’t come up the air filter restriction light comes on switch it off and it all goes away until I come down on the arms again the air filter isn’t restricted and the sensor is working fine I have also checked the door switch and arm rest switch they ar also good? Not getting any codes either. Any ideas would be appreciated.
Casper16
No I haven't got a scan tool and I’m not getting any codes out of the screen on the other side I just posted the photo for reference to the indicator lights.
I’m unsure what you mean by jump prefix?
Thanks
Post a photo of the panel on the other side please.
I was referring to the machine Serial Number. I assume it starts with JMP followed by xxxxx.?
Casper16
Ohh I see no JMP number is
RTD00475
Casper16
Ah, so you have a Series 2 machine. As you didn'tsay that I assumed that is was a Series I.
From the LH panel what do you have in the way of stored Codes and/
From the LH panel what do you have in the way of stored Codes and/or Events.?
No getting anything
Casper16
Hey mate I can’t seem to get them to display on the screen unless you have a trick on finding them so I’m assuming there are none if they are not showing up
Thanks
Let me find a copy of the procedure to get them to show up.
I just had to check to make sure I had the procedure correct.
With the key ON, to entor Service Mode press and hold the two outer buttons below the screen for 3 seconds then release. That puts you straight into Service Mode 1.
There are 4 Modes in total that show Diagnostic Codes and Events.
Mode 1 - Active Diagnositc Codes.
Mode 2 - Logged Diagnostic Codes.
Mode 3 - Active Events.
Mode 4 - Logged Events.
In each Mode however many Codes/Events that exist should scroll one after the other until the display comes back to the first one on the list. In some panels it is necessary to press and release the centre button once to scroll from the currently-displayed Code/Event to the next one.
Each Diagnostic Code will display on the screen in 2 steps. First the module identifier (e.g. 039) then after 1 second the component and fault mode (e.e. 2473 03).
To move from one Mode to the next one, press the RH button once and release.
To exit from Service Mode back to Operation Mode, press and hold the two outer buttons for 3 seconds and release.
Casper16
Thanks mate,
So active codes I have
2477-3. And 2474-3
Now we are getting somewhere.
Those are both joystick Codes.
2474-3 is for the LH joystick fore/aft position sensor.
2477-3 is for the RH joystick fore/aft position sensor.
It seems a bit strange that they have both come up at the same time.
Seeing as you are having issues with the bucket raise/lower I would suggest to diagnose the RH joystick Code first. See attached.
Do you have a multimeter capable of measuring duty cycle.? It would help a great deal with diagnostics.
  • MID039 CID2477 FMI03.pdf
