CAT 287C - Bucket wont move
Jared Rall
Willliamsport,PA
2006 CAT 287C, only warning light on is flashing exclamation point/driver alert, no beeping. No digital interface for code readout on this unit. Drives forward and backward but the right joystick will not do anything. The light went out and the bucket worked twice for about 10 seconds and then light started flashing and stopped working again. It is full of hydraulic fluid, oil and filters were changed 6 months/20 hours ago, full of fuel. It was sitting for about 3 weeks before starting it. Serial: CAT0287CHMAS01365
Does anyone have any idea whats wrong with it?
Thanks,
Jared
Jared Rall
Willliamsport,PA
e0O9wSldqa3uKr-UVbHaUPPQ8-MeOIzFQwa1BQIibY92p7LP6bxntLb1FT9VEvBJN9BxN0uCfc8MlixI7vgHNJeWwTYX7UBCZACExOlB9XPgjjbL5Km42OLVvR09de5XNi5JLSJT0klzjAkekB7wffrdelqOzeu3GGwwlU_4BlypYKNFdZHAUeOYJWt96emZtp3-E7DEQ5gWRwzV1aGVhbSG15-wjANkVobdjRxj-LlfoPP7tsHZ4xPpl4oyxZO4VONPdzSsmtlPsUfdGpnm7lGSU2RCoTs38QnnXOp2Uumcwr_IFvk0jeHLdawF6XZIKo7g6YzQUMUzDpuf-_ZmbP7Z3YExz6ptk2LNwbUR_RlBI9IZF33jTlwvcnbVsh5sWTxQ_21bNp2e6KmAMAZYXAbUJXgQzSNSnQj3BZGVTtss123zV5RNcAfY70EJRJuKqQWKvG9pW-6PK8jGEby2tYD3x7u0XTKoubS3qeaHC7BdO4OTFgv1q8TXFYrmRy6Ji6x6ZQb5-VVhLO4dm-S2MBIXcWv0JOlfRpBCr8ObmGL6d5WjzqJvYsmdqAFp03dzKpaHvENMkvZxO9Ktiiv_jH615kroWp6XW6K6JSuE9MdREz7RIoBvTgIe9yHSV1iDqCG2QJI4RxAUfqjatqCT89DKoJzy7USy_dS4pBycFMeZJpYyZxWW1qtaG1VECw=w1453-h1090-no
You should post this in the compact track loader forum. This forum is for larger steel tracked loaders.
Per Eriksson
Sweden
So both lift up/down and bucket rack/dump is dead?
I'd start checking for power and ground first at the joystick.
Then the 2 signals which is PWM so a multimeter can be used to check btween ground and signal. should be 50% at center position and go between 20-80% at full strokes.
If you have power and ground but no signal you can swap left and right joystick and see what happens, they are both the same.
Jared Rall
Willliamsport,PA
First off, sorry for posting in the wrong group. I would move it if I could.
I do have power at the right hand joystick, but I'm not sure that I am measuring the PWM in the correct location or have my multi-meter setup correctly to read it.
The right joystick has the auxiliary hydraulic rolling knob on top and it does bog the engine down when rolled forward or back.
The Peej
Connecticut
First thing I would check is the door switch. If its not seeing the door closed it will lock out the bucket controls
Jared Rall
Willliamsport,PA
Turns out it was the right joystick, the auxiliary button is a different wiring harness.
Does anyone know where to get a new joystick, or the module in the joystick as the rest of the joystick seems fine? Does anyone repair the joystick?
The joystick PN is:269-0262 with updated part number 460-5347. It doesn't appear there is a part number for the module in the joystick.
Jared Rall
Willliamsport,PA
Just more photos of the RH joystick. IT switched the left and right and the dump would work but the tracks wouldn't move.
Jared Rall
Willliamsport,PA
CAT 287C right hand joystick is the same as the left.
Looking for a new joystick, module or repair that isn't $925
Thanks
Good luck in that search. There are no electronic repair parts for that joystick.
Alternative Part Numbers. The bare joytisck assembly is 269-0257, replaced by 456-0166.
269-0257 & 269-0262 are both on Machinery Trader used. Says "call for price".
