Cat 279C2 Drive Problem
Continuing on from the two steps above. If the calibrations are all successful up to that point try ONLY the "Forward Pump Solenoid Calibration". If that part is successful and the calibration automatically continues to the "Reverse Pump Solenoid" abort it at that stage. An abort will not affect the successful Forward Solenoid calibration that you completed.
The reason I say that is that the 1706-5 Diagnostic Code that you have had at various times in the past is for Current Below Normal in the Reverse Pump Solenoid.
Test the machine at that point and let us know how it goes.
