That would probably be the best way TBH.New accumulators come uncharged. It's to do with airfreight safety regulations. If you don't have the equipment to charge it yourself, it's cheapest to take it to someone who can charge it before you install it.
Acksherley the precharge pressure listed in the 277C Service Manual for that particular Part Number of accumulator is 130 ± 15 psi.the label states 0psi precharge but tech is stating that it needs to be precharged to approx 280psi.
The procedure for checking the gas pressure of a sealed precharged accumulator is somewhat different that for to charging/checking an uncharged one. See attached which also mentions the precharge pressure specification.They set it to 280psi. I guess I need to go back and have them set it at 130. The one that came out said to charge to 130 but it is a sealed unit. So I thought maybe the precharged changed with the new style.
You mean to say it was a dealer that charged it..? When you go back ask them is their SIS broken........!!I will go back to Cat and have them relieve the pressure to 130psi.
I'm going digging. I have a new pick & shovel to work with but this may take a while.........They told me that for the new part number this is what the charge is.
You would need a mechanic who has a nitrogen charging kit containing the correct connector (there are various) to fit the charging valve on the top of the accumulator. At this time you need to refer to REHS5464 which is attached.If I were to decide to take it else where to get it corrected, who does this kind of work or is Cat my only choice
Excavator application. I found the same text that you found in AVspare in the Specification section of both KENR9854 (316E) and KENR5513 (320E RR), but nowhere else.I highlighted the spec that calls for a pre charge of 261psi. Thought I share to see if anyone may recognize where this info may have come from.
