Thesteeleboy
I have a cat 262 skid steer, Recently I got in and started it. It started and sounded good, I started running it and while setting still as I raised and lowered the bucket it started jerking like something was binding up trying to go up or down. I shut it down and then restarted it, before I pushed the brake release button enabling the bucket and moving control's it sounded good. after I pushed the brake release, as I started lowering the bucket I noticed a a change in the tone of the engine that happened the same time as the bucket bound up again. I then re-started, released brake engine sounded good, dropped bucket, everything sounds good then about half way up it stopped again and I could tell the engine was under load again. I then noticed a clicking noise coming from toward the engine or pump area that happens the same time the engine goes in and out of under load while just setting their and also while operating the controls to the bucket when it changes to the non-load the bucket works, Also while tramming the machine the engine slows and then speed up and while it is slow the bucket function hangs up. I'm assuming I need to check the electric hydrolic control valve for a loose wire or a sticky valve but have never done it before, Do I have to remove the cab? or where should I start. I'm too old for this crap but here we go if someone is kind enough to give me some pointers. Thanks Guy's
