phil smith
how do you replace speed sensor on a cat 259d
If you switched the wires from left to right then the 2688-8 (RH #2) should have changed to 2686-8 (LH #2 sensor). You did interchange the complete 4-wire harness from left to right and vice versa, correct.?I switched the wires from the left and right and it changed to 2687-8 right #1
yesIf you switched the wires from left to right then the 2688-8 (RH #2) should have changed to 2686-8 (LH #2 sensor). You did interchange the complete 4-wire harness from left to right and vice versa, correct.?
I am not convinced just not sure where else to goSomething doesn't make sense to me but if you are convinced it's a sensor then crack on.
