Hi Guys
Trying to help my son diagnose a 2015 CAT 259D with 2092 hrs, serial FTL03587.
Initial symptom was no crank due to low battery, jump started and ran all day.
Drove it onto trailer and off trailer into the shop and next start attempt was a no crank with the E459-2 code.
Charged battery , checked a number of grounds, checked fuses and still no crank with E459-2.
Looked over the couple of posts on the site and will check the engine grounds and diode harness at rear.
Found a power block inside engine compartment left side forward of fuel filter with a B+ lead from battery and
a couple of 50A fuses that looks very corroded but i was able to read battery voltage on the posts of the power block.
Was going to try and clean up the interface but worried if I try to break the nuts free the studs may break due to corrosion.
No schematic and unfamiliarity with CAT component locations is really hampering the troubleshooting.
Wondering if a Engine ECM or Machine ECM power relay is not engaging preventing CAN bus traffic between ECM's?
Anyone know how I can find an electrical schematic for this machine please? Thanks in advance.
Tony
Tony
