Satish
Hello, I have the infamous left speed sensor 2685-8 "Left Speed Sensor #1 - Abnormal Frequency, Pulse Width, or Frequency"
I pulled out the harness that goes from the sensor connector (outside and just under the tracks) to the inside connector underneath the cab. I checked the wiring while shaking the harness around and all seemed okay.
The wires from the sensor to the sensor connector (under the track...about 12" long harness) all visually seemed okay.
I noticed that the sensor is held on by an allen screw. Does anyone remember what size allen this is? 6mm? SAE? Metric?
The screw looks very dirty and worn. I'm afraid that using an allen socket on an extension will probably strip the screw. Anyone had any similar situation happen?
BTW, does anyone make a guard to properly protect all the wires and hydraulic lines on each side underneath the tracks??
