Inland1
Machine keeps running at very low rpms after key is shut off. I figure it is the shut off solenoid failing but, could use any helpful info on changing or any other possibie problem. Thanks.
Yes, the sol. on the rear is the shut off sol.
I think the CS Sol. is on a timer..??
Removed the shut off solenoid and inspected, did not appear to be damaged or sticking in any way. Reinstalled it and the problem is much worse, have to bog down the aux hydraulics at full throttle to kill it now.... will try a new solenoid and report back.What..?? U get 12v w/ the key on.. & 0v w/ it off is exactly how its supposed to work.. 12v= run.. 0v= stop.
Yes u can remove it on the engine. {open end wrench} U have to pull the boot back & remove the 8mm nut to get the wire out of the way..
Update:Removed the shut off solenoid and inspected, did not appear to be damaged or sticking in any way. Reinstalled it and the problem is much worse, have to bog down the aux hydraulics at full throttle to kill it now.... will try a new solenoid and report back.
Yes.. thats the fix if u dont know what yer doing..
They would have been able to adjust it on the test stand if they tried..
& THATS WHY the new H&R worked, they adjusted it on the T. Stand..
Hell, u could of done it but u never contacted me..
Live & Learn I guess.. Glad yer up & running..
