Good evening. Question about the A/C on my cat skidsteer. The air conditioner works, or at least blows a little cooler air than outside temp. But when you turn it on it runs normal and quite for a bit, then it starts making a “rumbling “? Noise, sounds like it’s coming from under the seat. I also notice when I turn ac switch on, the left joystick will move ever so slightly. So before I raise the cab I was curious what I should be looking for. Thanks
