David Campbell 1461
After a bid of troubleshooting, I’ve determined that I’m not getting power to the fuel cut off solenoid. The fuse is good but no power. Ideas?
Thank you very much for the schematic. I was able to trace the wiring and found a wire that hade gotten broken when we changed a hose last week. just bought the machine 2weeks ago. Still have a lot to learn about it.Same as 248b
Thanks for the pointers. It was a lot of help!Take a good look at the bottom of page 12 (Harness & Wire Symbols) and the tables in the bottom RH corner of Page 13. They will help you a lot when it comes to interpreting what wires do and how to figure out references.
Found the problem. Thanks for the help.Safety switch.??
Blown fuse.??
Have u hot wired the solenoid to see if it’s good. (Engine starts)
And it was.......??Found the problem.
Ah ha. So somebody got creative with the wiring at some point in the past.?It was a wire that had gotten pulled loose when we changed a hose. For some reason it was not in the harness and was spliced.
