Simon C
- Joined
- Jul 1, 2015
- Messages
- 3,093
- Location
- Rocky Mountain House , AB., Canada
- Occupation
- Heavy Equipment Mechanic
Once you have verified if the starter cranks with good cables or booster cables used as by-pass you will need to find out if you have clean power to the White wire at solenoid. I do not have the method to retrieve codes on " C " models, only on D models. You could have a relay problem or a signal to relay problem that is controlled by the engine ECM. I may have the schematic for this unit, have to check it over. Nige sent it to you. Start with the first tests and see what you find.
Simon C
Simon C
