CAT 24/M grader
Finish Blademan
Belton,Texas
Sitework superintendent for Wolff Construction. ww
That is a monster blade. I would kill for a day in the can of it.
johan7
the Netherlands
Hello , here is a pic of a 24M , found by my grandson in a Canadian mine . I don't know why the machine is completely supported , probably for getting new tires . Anyhow , it's impossible to steal it , if you wanted so .
Have a nice day , johan7
Finish Blademan
Belton,Texas
The amount of investment the mine operation puts into one of these beasts is substantial but I am sure the return on quick turn around time from the pit to crusher, stockpile , screen etc more than pays for itself keeping good haulroads.
big ben
Vancouver Island
The machine is brand new and supported because when they arrive from the factory and on site they need to finish being assembled including installing tires. Still needs ripper and moldboard installed also
PS Usually the front tires are installed the with the traction bars the other way. Not sure if this was done this way for a reason or by mistake
cuttin edge
NB Canada
Finish grader operator
I've been trying to get my company to turn my front tires around since the grader was new. But what do I know. She has the snow tires on this year, Hoping I can be the one to bring her to the tire shop in the spring, and get them on right.
alco
here
I've never seen the front tires on a 24 installed the other way, and we have 16 of them.
big ben
Vancouver Island
On smaller graders i have seen this, but on a 24 not yet on pictures. Wow you have lot :)
What about the Kidco 24H youtube link you posted in this thread ?
Every 24M I assembled or saw assembled we put the front tires on the opposite way the drivers were installed as this was the way I was told its done. Not sure if it makes a noticeable difference or not (since I'm not a grader operator) but the theory is correct.
Graderfan1981
Germany
You're right, I have made a bigger view from the video and stopped it, i have seen now that the front wheels are the other way.
cuttin edge
NB Canada
Not sure about the 24, but they do make a difference when cornering with a full blade. I was always told that the only time they are the same as the drives, is when you are runnin a six wheel drive.
johan7
the Netherlands
Hello graderfan , your "special ripper" is , to my opinion , more a device to smooth out any lumbs , in order to get a cleaner haul road .
In the Netherlands there are some graders for road maintenance that have about the same "ripper".
Have a nice day ,johan7
Graderfan1981
Germany
Yes I have seen, when a smooth ripping is needed a good thing, but better it is possible to switch both, when you need for deeper heavier ripping, the common ripper is better. But here on the 24M there is a common ripper where the special smooth ripper is installed. Here it is possible to switch to the bigger ripper shanks again when they need it.
Here is an example too:
https://www.heavyequipmentforums.com/showthread.php?57410-Motor-Grader-V-Pick
