ThreeCW
So I started my troubleshooting. I drained the fuel bowl of the water separator until it was empty and then pushed the primer pump. With each push of the prime pump, fuel entered the bowl and drained out the open drain of the water separator. I pumped perhaps two cups of fuel and assumed that the fuel line from tank to filter housing was clear.
I closed the filter drain valve and disconnect the outlet line from the fuel filter / water separator housing. I again pushed the prime pump and the sediment bowl filled up and at the same time foamy diesel fuel discharged from filter housing outlet. I pumped the primer for 15 minute and recovered perhaps twice the filter assembly volume (about 1 quart) with no change - still very foamy diesel fuel coming from the outlet.
I then disconnected the fuel pump discharge line and had my wife crank the engine to check the mechanical fuel pump operation. When cranking, there was a very small amount of fuel discharged but it consisted of only a few drops per stroke, with not much measurable volume.
As per “heymccall’s” suggestion earlier in this thread, I completely disassembled the fuel filter / water separator housing and checked for plugging as per his post … it was clean as a whistle. This was just a preventative check as the discharge test of the fuel pump had obviously failed.
I then remove the air filter housing / mounting bracket to make room and then pulled the fuel pump. My thoughts at that time was the fuel pump had failed.
As per “03spfld’s” suggestion earlier in this thread, I removed the cap on the fuel pump and found the filter basket in the pump to completely plugged with debris … bit of grass, dirt and grime that were completely plugging the filter basket (see photos below).
I cleaned up the filter basket and blew it out with air. I also replaced the O-ring on the cap, as the old one was in pretty bad shape. I mechanically cycled the fuel pump a few times before installing and it was spitting out fuel, so it appeared operational.
