Sorry, the links are 9K6628 and 9K6629 (inner and outer?). There are some newer links that are 9K6629H and there are a few that are aftermarket. Asparco? or something like that but could not get a certain PN from them.
I know these chains have seen better days and frustrating because it really doesn't need to go far these days but if it can't track, that is an issue.
I have 2" of slack in the tracks right now between the top roller and idler.
I think the target pitch on these is supposed to be 6.75"
I am not sure what a reasonable wear limit is on the pitch but at this point, I am not sure where the issue is to determine what to do about it. I don't think it would be too wise to try to patch things too much rather than just replacing and I would be I will have my work cut out trying to press those pins. Well, some of them are literally steel bar stuck in there and welded!! There were running it around with bad lower rollers and grinding on them until they were VERY flat.
Is there a way to determine if the pins are very frozen to where lubing them could help for now? Tracks are so heavy that it makes assessing things difficult. I know when I jump on them, they seem to move pretty free.
Regarding the idlers, maybe I am wrong but I would think if that was the sort of my binding I would either see the track slip on the idler causing heavy marks or fresh meat where the idler was making contact with something?
When I look at how the pins ride the sprocket, they make contact with the front side of the tooth, then "pop" in steps down into the root of the tooth, then exit on the opposite side of the tooth.
As well, I read in another post where someone mentioned that binding and track issues can further cause final drive failures? Is this due to the extra load or something else?
