Dgreen4298
i have a cat 215 that has been giving me some trouble. I am not sure if I have an engine power issue or a hydraulic issue. The problem I am having is the hydraulics are pretty weak. I had a couple of fuel problems that have been straightened out, rebuilt fuel transfer pump and new fuel lines and pick up tube in tank. Engine starts and runs well, no more missing and primer pump works as it should. Fuel pressure at injection pump is around 30-40 psi. When trying to dig with bucket or swinging with a load it just won't go like it should. I installed a pressure gauge in the top of the injection pump as advised and after about 20 minute I notice fuel leaking and found that the gauge had filled with fuel and blew the vent cap off, this happened twice. Gauge was a 60 psi gauge. So now I am wondering if I might have a fuel injection pump issue where it is pressurizing the feed line somehow.i am going to try a 160 psi gauge.
One thing that I noticed is a slight hissing sound coming from somewhere in side the left door where all the valves are. I can't tell which one it is coming from and I am not sure if it is normal or not. Also when I move the levers and machine won't go I can hear hissing in the hydraulics like it bypassing or something.
Machine serial number is 95z00480
