RandyAndy1982
Evening, folks, I’m new here so take it easy on me.
I’m a long-time truck mechanic, starting to venture into the equipment world. Things have been going pretty well, but I recently took on a job that’s got me stumped.
The machine is a Cat 140H, I believe about a 1997 (PIN 2ZK02124) with parking brake issues.
When you start the machine and let it build air, everything seems fine, though the air builds all the way up to about 150psi. The low air alarm doesn’t turn off until ~90psi. That’s a bit different than I’m used to from the truck world, so I want to verify that it’s correct.
At this point you can release the park brake and everything is fine - however, if you happen to use the brakes or somehow drop system pressure to around 115psi, an air leak “appears” out of thin air, coming from the transmission vent. Once this starts, that side of the tank will be empty in about a minute, maybe 90 seconds with the engine off/key on.
HOWEVER - if you start the engine and build pressure back up to 120 or so, the air leak will stop and it will hold pressure even if you shut the engine off again. Step on the brake (or vent some pressure out of the tank drain) and hit 115 again, and the air leak reappears and drains the tank.
During the time that it’s leaking, if you drop the lever back into Park, the leak will stop. If you turn the key off, it stops. Turn the key on and take it out of park below 115psi, the leak starts again.
Pressurize the system above 120 with an outside air source, and the leak stops.
During the leak, the park brake starts out released, but the pressure falls so rapidly that it applies within 20 seconds or so.
It’s the damnedest thing. I’m 90% sure it’s got bad seals/o-rings in the parking brake assembly - I mean, what else can it be? The other thing is, it’s dead-nuts consistent. Does it every single time you meet the parameters.
I’ve checked the whole system from where the parking brake air supply tees into the right-side supply line from the tank to the service brake valve, the check valve, ignition-controlled park brake air solenoid, the park brake control valve in the shift console, and the hose to the park brake from that spot under the right side of the cab. All of these components seem to be normal.
So am I right in thinking the park brake seals are shot and just happen to be leaking in a certain pressure zone?
And what pressure should the governor be kicking out at - or is 150 or so normal?
Thanks in advance, everyone, and thanks for letting me join the forum. Good night!
Randy
Randy
