Hello guys
On monday the operator of this grader called us telling the drive circle shaft was broken. This is not the first time (it might be the 4th). Previously they welded the shaft and re use it and this is the one that broke down.
So we bought a new one (I told´em so) and we put it. Now I´m having serious doubts about the clutches for the drive circle. Don´t know if they´re working. When I took the shaft out, I noticed a lot of washers (really thin). What I dont know is if you put more washers the blade is more sensitive to logs or to the contrary, it will resist more knocks but braking the shaft.
BWT, here you have pics from the circle when I removed the shaft. Look the gear and crown
