Onfoot
Appreciating already the collective wisdom and experience that resides in this forum! Especially given my newbie status.
As noted in a previous post, I am a newbie with a 1968 (maybe 1967 according to S/N, 59H498) 12F grader, affectionately known as Hanna. Starting was not a problem until I (foolishly, I now know) followed the instructions on the plate in the cab--leaving Heat on for a full two minutes before trying to crank. When I then went to crank, nothing happened. This led to all kinds of sleuthing--determining that the batteries were fully charged, that no fuses had blown and that the manual breaker switch had not tripped.
If I turned the master power switch off for a bit, then turned it back on, turning the start switch to Heat would produce some rattling in the solenoid relay. I replaced the solenoid relay thinking it might be the problem. But no go. (See attached photos to see all that I am referencing.)
I have wondered about the breaker switch, but if I bridge the two leads, it makes no difference.
However, if I connect the hot lead on the start switch directly to the positive battery terminal, everything works fine--the glow plugs glow (at least enough of them to start the engine--I think one or two might need replacing) and the starter works fine. And, once the old girl is running, I can disconnect the lead between the battery and the start switch and everything seems to be working fine. (Until I need to start her again--whereupon I pull out the alligator clips.)
Does anyone have any ideas about what I should test and how such testing might be done? Electrical is not my strong suite!
Thanks, guys! I am really wanting to get Hanna restored to her former glory.
