gggraham
- Joined
- Feb 13, 2009
- Messages
- 589
- Location
- London Ontario Canada
- Occupation
- Licensed Heavy Duty Equipment Mechanic
Amunder. The switch listed with a switch/knob/washer/screw may not all be nec. The old switches had a hex shaped post, the newer upgraded switches had a square post. If you have a square post switch all you need is the switch. If the post is hex shaped you need the switch and the knob. Assuming you can get the screw out of the other switch.
Check your email, sent you a schematic from a training manual may help with the RTD problem.
