Case W20B Transmission Problem
myersabr
PA
I have a Case W20B that seems as if it doesn't want to change gears in forward. Reverse seems to still work well. Engine is strong, hydraulics work well, strong air pressure. Any advice would be helpful.
Coy Lancaster
Arkansas
service tech
Have you checked the trans pressures for the forward clutch? Also check the service brakes for binding up and not releasing all the way.
myersabr
PA
I have not checked them, my brake pedal is also down when running but it has been like this for 2 years since I purchased it
myersabr
PA
Do you think this may be some of the issue? I have not owned a machine this large before so I am just getting into the repairs
