shakori00
I just finished power washing my 2011 TR320 compact track loader. I got in it to put the bucket down and it won't move. I can start the machine but cant move it or the bucket. I get an error code of OPRPR. Any suggestions?
sounds like a safety switch, maybe lap pull down or seat sensor, that may stand for Operator Presence.
Fallentimber1 Sounds like you have old software. The old software would glitch out, if the seat switch was turned on/off/on too fast. This happens usually when you get in the cab, because most people sit down, and then adjust themselves into the seat. Your only getting the OPRPR code too?
Is the lap bar light on? If you raise then lower the lap bar, does it work?
When did you have Case do the software update? Software to address this came out late 2013/ early 2014.
I have had some problems with the lap bar switch. Its a magnetic proxy switch. I had one where a small washer got stuck on it, and would randomly turn on/off the lap bar. Also had where the wrong bolts were used on the lap bar switch, and would mess with the switch.
Also check your gap between the lap bar and the proxy switch.
When your having the issue, try putting a washer or something steel by the lap bar switch.
