Case sv300 acc. Fuse
Case sv300 machine, l.h. window leaked and fuse panel was full of water. I dried it out, replaced fuses and relays, machine ran for 10-15 hrs no problem. Now has started to blow 20 amp accessory fuse as soon as power button is turned on. I have found that the load side of fuse is shorted to ground, but cannot pinpoint where. I have removed instrument cluster, radio, fan switch from circuit also unplugged seat as all of these are tied I to acc circuit it looks like. Anyone have any input, maybe a common prob with these machines. Thankyou.
Midnightmoon
Ny
id start at accessory relay swap it with another one. If that doesn't work i would jump a resetable breaker where fuse is and start unplugging all the accessories on that circuit until it doesnt pop the breaker then go from there.
