strykerakamack
Ok was getting OPRPR code occasionally with the lap bar being the problem not too bad as had like a 15 second delay
before machine would stop but not shut off .
Then I get OPRPR with immediate engine cut off .( this was due to seat switch )
Replaced both , closed machine back up lowered lift arms , regen came up let it run for its cycle and shut it down .
Now when went to restart it went thru normal prestart beeps as usual , started up than ran for 15 seconds and shut down .
Im now getting codes 3659 , 9153 ,1051
Now in book these codes relate to the can bus system and high voltage .
the battery has 12.6 volts .
Any ideas where to start looking ?????
And can cab be tilted forward with the arms down ?
Can't see how replacing two switches leads to a can bus failure
Thanks in advance for any help
